trouble with toggle switches
9 Feb 2014
Hi all
i am trying to wire a led toggle switch to the cathodes inside my pc but i cant get it to work. it works when i only use the power and acc pin and i don't put the ground in but the led does not work.
when i do put the ground wire on, i split the cathode ground wire and solder the ground to the toggle but it shorts my computer and shuts it down
Please can anyone help?
Cheers :)
Yes you need to remember LEDS are diodes that emit light so they need to be wired right way round, they are not bulbs that can be wired any way. Also as they work like a diode they can stop current traveling down the wire if wired wrong to other devices.
