Was thinking of picking up this cooler to replace my Zalman CNPS9500-NV, as the load temps peek into the 60C range with a clock speed of only 2.8
. New case is the CM HAF 932 and all my other temps EXCEPT CPU have dropped anything between 5-15C which is rather odd.
Anyway, Ive looked into fans for this and was looking at Yate loons and Noctuas but theres so many other 120mm fans with similar CFM and RPM's that im no longer really sure whats best, so any help on that?
2nd question would be, would i need a bolt thru kit or a backplate for my Asus M3A32-MVP ? My understanding is that i don't as the board has a metal backplate already...correct my if i am wrong please
I still need to measure it up so it fits, but i have to use the RAM slot closest to the CPU, which is rather tight
Config:
DIMM-A1 DIMM-B1 DIMM-A2 DIMM-B2
FILLED EMPTY FILLED EMPTY
Any help is appreciated
PS - I would like to get the clock speed upto around 3.2 if the MB keeps up, i have need to up the voltage from 1.3 ( Actual is 1.28 ) to 1.325 (Actual is 1.312), and thats only on a multipler change.
. New case is the CM HAF 932 and all my other temps EXCEPT CPU have dropped anything between 5-15C which is rather odd.Anyway, Ive looked into fans for this and was looking at Yate loons and Noctuas but theres so many other 120mm fans with similar CFM and RPM's that im no longer really sure whats best, so any help on that?
Config:
I originally purchased them when trying to push my oc that bit higher (without using deltas) the fan controller helps to tame them though, down to a level of noise which is better than the yate loon 1200 rpm fans i had in my case and 2 arctic 400-1500 rpm pwm fans on the TRUE.
