Zotac's twin edge are usually compact cards, e.g. the 5070 is listed as 40.6mm.So perhaps something around a RX 9060XT 16GB, RX 9070 or RTX 5070 would work well?
9060 XT Gaming OC (Gigabyte) says 40mm, if you want another option.Perfect thank you both![]()
Same here on the 9070xt side, it's really not that loud considering the form factor.Got a Powercolor reaper 9060xt 16gb, its a true 2 slot, both width and height and really short. So fits in pretty small cases, and performance is solid
My basket at OcUK:
- 1 x PowerColor Radeon RX 9060 XT Reaper 16GB GDDR6 PCI-Express Graphics Card (SKU: GRA-PWC-05257) = £329.99
Total: £329.99 (includes delivery: £0.00)
