Trunking & Picture Rail Advice
19 Jan 2003
Bristol, UK
Today I rewired my network.
This consisted of running some cat 5 around the house via the attic.
I have all but finished, just need to get some trunking to run the cable in.
The problem I have is that I need to run one piece of trunking vertically down the wall. Around 10ft in total.
The picture rail is about 2 ft down the wall from the ceiling.
How can I go "over" the picture rail but still maintain a tidy job.
Hacking bits out of the picture rail is not an option,
Mat said:
Stop the trunking above and below the rail and paint the cable the same colour as the rail?
That would still look a bit crap I think.
I thought about having two seperate rear parts but one long front part and bending the front over the picture rail
Is it possible to detach the rail from the wall, cut a small channel in the wall and stick the rail back over it? sort of tunnelling under it in the wall??
Drill down behind the rail from above and up behind the rail from below, keeping both holes as near to the vertical as possible, make the hole a bit bigger than the cable you want to feed through it and you will have a 'dog-leg' shaped hole behind it, that you can feed the cable through... apply trunking above and below the rail, and cut a slot out the back of it to accomodate the wire going behind the rail
