Ive spent the past 3 days pouring over the net and have learned a lot but my brain is turning to mush trying to figure something out. I need a second oppinion.
I currently have a 3700x cpu and an arctic freezer esports duo air cooler. I have the money there to upgrade to either a 5800x3d or a 5900x. I was going to buy a new cooler. A noctua nh u12a or a d15. But for various reasons this is not ideal. So i started looking into if my current cooler can handle the new cpu. This is what i found out.
The esports duo is only a few degrees worse than the d15 and 1c worse than the u12a, even though it only has 4 heat pipes. This is due to the esports duo having direct pipe contact.
The esports duo is almost on par with a 240mm aio
The esports duo is a 220 watt tdp cooler (not easy to find out) so in theory it should be able to handle a cpu at 142 watt tdp
Yet most people on line scream that the esports duo isn't good enough despite the above.
Is there any point in shelling out over 100 for a cooler thats only a few degrees better? Shouldn't i just stick with the cooler i have? I'm basically stuck that way anyway. Because the standoffs for the esport duo are jammed solid in my motherboard. I would need to take a pair of pliers to them to get them off and risk damaging the motherboard in the process. I don't want to walk that path.
