Trying to update SSD firmware - PC wont read the disc I have burnt
18 Feb 2010
Essex
Hi Guys
I am sure this is trivial but bloody annoying
I am trying to upgrade the firmware on my Crucial M4 256GB
Its brand new - I have not done anything with it - I thought it made sense to update the firmware first.
I have downloaded the file from the crucial site - burned it onto a CD with Nero. Also tried burning to a DVD and CD with windows.
In Bios set IDE and Boot Priority to DVD Rom
It then posts the BD Rom light flashes but it doesnt detect the disc and says operating system not found.
Obviously I am asuming I have bearnt the disc wrong or something simialr
Any help would be much appreciated!!
Thanks
When you look at the disc in Windows, what do you see on it?
Just a 'C400-0001-or-0002-to-0009-Crucial_00.iso' file or a 'BOOT' folder and 'REVISION.TXT' file?
You're aiming for the latter.
'C400-0001-or-0002-to-0009-Crucial_00.iso' is a disc image file and must be burnt as such.
Windows 7 has a basic disc image burner built in. Failing that, use something like ImgBurn.
when I look at the disc I am seeing the c'400...... .iso
How do i use the win 7 image burner and thanks for the help
simple soultion
I was dragging and dropping the file to burn it
Double clicking it opened in nero to burn as an image, I am now getting the boot / revision folder you mentioned
what a wolly I am and thankyou for the help
20 mintues to Crucial tech, he didnt think of it either!! lol
not tested yert but am sure it will work now thanks again
