Tubing and fitting issue
29 Dec 2012
can someone help me, i'm having issues getting the correct tubing, ive ordered 2 lots now and the O/D on both has been too big, and I can't find any size on the fitting, or remember what size the tuning I use before was.
Without knowing what size your fittings are or at least what tubing you have tried, can't really help.
Measure the tube you have first then how much smaller does it need to be?
The size ive tied
Outer diameter: 15.9 mm (5 / 8 ")
Inner diameter: 11.1 mm (7 / 16 ")
Outer diameter: 16mm (5 / 8 ")
Inner diameter: 10mm (3 / 8 ")
both are 5/8 O/D I thought one was 1/2 O/D
OK,
The I/D size on both tubing fits he 3/8 was a bit tight, but the O/D was bit big, what other size are there smaller then 5/8?
