Here is my planned layout for the components in my build (Starting next week if everything arrives promptly):
I'm using all EK components (bar tubing), which are as follows:
- Rad - EK Coolstream XT 360
- Res - EK Multioption X2 150
- Blocks - 2x EK FC-5970 Copper-Plexi
- Pump - EK DCP 4.0 18w
- Tubing - 5 Meters: 1/2" ID - 3/4" OD Thermochill Flex Hose
- Barbs: 11x EK 12mm (1/2") G1/4 High-Flow Fitting
Please see the following picture:
** No Hotlinking - Please rehost before replacing **
That "tube" coming from the bottom fitting, on mine this is coming from the top. I cannot undo either end of the res (second hand, not sure if it's been glued), will this have any affect on the performance of the res? Also note, I will be using Mayhem's Aurora Tharsis Red coolant.
