Tubing
7 Sep 2007
Guys,
Does anyone have any suggestions as to where I can get 1/2" ID Clear tubing from. As ocuk are out of stock and I am about to place an order for a new system which is pointless without tubing :(
do you know if the frio air cooler that comes with the msi z79 board can handle a 4ghz on the 3630x i7 chip?
are you seriously comparing a custom water loop to a low-end air cooler?
i would REALLY not put that cooler on that chip at that overclock :p
Cleeecooo
I'm probably going to choose Tygon tube.
Isn't there a danger of getting splits on the 7/16 tubing? over time? - whats the longest you've ran your system on these? I mean the clips cost is negligible so going for 1/2 ID won't make much of a difference. I'd like to keep my loop running for at least 2 years.
