Tubing
Cleeecooo
I'm probably going to choose Tygon tube.
Isn't there a danger of getting splits on the 7/16 tubing? over time? - whats the longest you've ran your system on these? I mean the clips cost is negligible so going for 1/2 ID won't make much of a difference. I'd like to keep my loop running for at least 2 years.
Tygon's good stuff. I haven't been watercooling for 2 years so can't answer that for certain, but i'm pretty certain that it'll hold. Tygon and masterkleer are nearly as good as eachother :)
ON AIR?!
put both that chip and graphics under water and experience the awesomeness :D :cool: :D
+1
not much of a cpu waterblock selection for 2011 socket, any ideas?
EK supreme HF
using 7/16" tubing & 1/2" barbs without clips is a bad idea overall, i have done it before the tubing ends up becoming loose over time and simply pulling the tubing would make it start coming off. Just buy a few zip ties to make sure.
looking at the mayhems but looking for a nice color to go with the msi board and then got the problem with no clear tubing :( cant believe ocuk have not got ample stock of the bare essentials such as tubing?
It depends how long you use it for, it's fine for 6-8 months in my experience
High demand
I think the Asus is the only one with a modded bios
Edit: Quick look. XFX at the bottom. You have to remember, these are still new cards. You will have to wait a few months for some real hitters.
