Tubing
30 Jun 2013
Gutersloh, Germany
Moring all :-)
I'm looking into setting up my PC with a upgrade of CPU & GPU, and also at the same time looking to WC it.
I've got my basket full of everything i need other then tubing and fittings.
The Blocks and rads are all G1/4" EK branded threads, do i require the tubing to be 3/8" - 1/2" or 1/2" - 3/4".
And the same goes with the fittings, i shall be investing in compression fittings so same as above with sizings?
Thanks
Gaz
You can use any size barb / tubing that you prefer just need to match those. Fitting onto your blocks and rads will be the same.
Your fittings will all be 1/4" (the threaded part that goes into the block, rad, pump, res etc...)
The barb end (E.g: 3/8"-1/2") has to match the tubing size
