I'm looking to buy a Tumble Dryer. After reading threads on here and various articles, in the long run it seems to be better to go for a Heat Pump Tumble Dryer because they are cheaper to run.
With a household of 4 I suspect it will be well used most/every other day throughout Autumn/Winter.
We've currently got a Samsung EcoBubble(?) 9KG Washing machine, so thought it would be good to try and match them up as they will sit next to each other.
I've looked around on AO, Currys, JL (sorry if I'm not allowed to mention these retailers?) and there seems to be quite a variety on Heat Pump models available from Samsung @ 9kg...
Is there a particular feature I should be going for on these? they all seem to be the same load/energy efficiency...
EG: DV90M5000IW vs DV90T5240AW - Is one just a newer version of the other?
Should I consider another brand/model? anything else to look out for? What make/models have others got that they would recommend? I think my max budget would be £750 unless spending more would get me something much better or offers an option/feature that is really good.
