- 22 Dec 2010
- West Midlands
Our Beko Heat Pump Tumble Dryer is doing a grand job - 4 1/2 years old and still going strong.
it really doesn't. besides we don't heat our conservatory in winter anyway unless we specifically plan to use it.The heat pump dryer is taking heat out of your house to do the drying .. so even if immediate electric bill is less it's taking some kwh's of energy from your house too,
albeit the gas is only 4/5p / kwh, so net cost is less than condensing ...
possibly a close call if you were always drying overnight on octopus ev rates.
I mean... why wouldn't it work? People are using heat pumps outside to heat their homes. Sure its a bit less efficient but should still work.Got a Samsung heatpump in our garage, works just fine, takes a bit longer when it's colder.
Faster and heatpump just don't go hand in hand. Mines typically 3h to 5h but uses almost no energy.Any recommendations for a heat pump that doesn’t take forever to dry a load of washing? Bought a Hoover one when money was tight and the old condenser one died but it averages 3 hours for a load. With kids it is slowly driving me insane.
My LG one in the conservatory doesn't take 3 hours. Also, what drum speed is your washing machine?Any recommendations for a heat pump that doesn’t take forever to dry a load of washing? Bought a Hoover one when money was tight and the old condenser one died but it averages 3 hours for a load. With kids it is slowly driving me insane.
Want to buy a tumble dryer but not sure what to go for.
Heat pumps are efficient, but expensive. And have read mixed reviews on them - some say they're the best thing ever, others say they're a waste of time.
Vented are cheap and simple, but require a vent. (I've only ever used a vented).
So thought about the condenser option. Are these on par with a vented machine, and just collect the water instead? Or are they worse with drying times etc?
Your thoughts are welcomed!
We had a Hoover condensor and it took forever to dry stuff.Any recommendations for a heat pump that doesn’t take forever to dry a load of washing? Bought a Hoover one when money was tight and the old condenser one died but it averages 3 hours for a load. With kids it is slowly driving me insane.
5 hours? I’m a single dad I’d never get the washing through on a weekendFaster and heatpump just don't go hand in hand. Mines typically 3h to 5h but uses almost no energy.
It’s a fairly decent LG, no idea what speed but the clothes come out pretty dry.My LG one in the conservatory doesn't take 3 hours. Also, what drum speed is your washing machine?
All depends on the setting used, you can use a faster setting and a full 9kg load will take 1h but use a load of electric, but if your doing that all the time you might as well have just got a condenser dryer. The 5h time is for the no heat setting which I guess is similar to a room with a dehumidifier in it.5 hours? I’m a single dad I’d never get the washing through on a weekend
Seen some reviews with people saying they’re doing loads in an hour but tend to trust opinions on here over review sites.
Yeh the ROI wont be worth it if you already have a decent tumble dryer.
But, as you say if buying new, you can get them for quite reasonable amounts of money now so it is the way to go.
We've found splitting the load in half works much better than trying to dry the lot in one go: we pull bigger items out and hang on an airer, put the smaller stuff in the dryer first. Once dry, put the bigger items in.Any recommendations for a heat pump that doesn’t take forever to dry a load of washing? Bought a Hoover one when money was tight and the old condenser one died but it averages 3 hours for a load. With kids it is slowly driving me insane.
