conuk said:Is there any point in changing the fan in the Tuniq Tower 120 ?
If so - what to ?
Or is there better coolers now for this chip - dont want to go H2O
Trying to keep my 6700 a bit cooler - room is hot as hell![]()
Cyber-Mav said:im already using a different fan to the stock one, im using an arctic cooling fan. although i hear the best one to go for is the scythe s-flex 1600 fan. bit expensive but i guess its just gonna be a one off payment then im done with spending cash on this pc.
Zefan said:tsj I thought I'd just take this opportunity to remind you that your sig is above the maximum filesize allowance.
:edit: In fact here's a quick re-compression of it for ya if you want to use it that is.
It's still 25 pixels too wide but the forum formatting seems to cut off any pixels over 400 anyway.
conuk said:got one of these... guess ill chuck it in and see what the score is .. will report back.
Temps - stock 45-48 then rises up to 59 under load... have fan controller so at full pelt gets to 58 .... gonna check seating and paste ... theres a difference of 4d on each core.. this about right ?
