Hi all
I have a good old fashioned tuniq tower 120 sat on a q9550 in an asus rampage mobo @ 2.8
I am having real problems with this thing
Idle:
Fan full blast:34-39 (across cores)
Fan turned right down 34 - 39
100% load
Fan full blast: 44-51 (across cores)
Fan turned right down 46-54
The CPU block is cool to the touch at all times
I have just resat the thing with IC Diamond paste. Tightened the screws till they pretty much could go no further.
When I over clock the thing the temps jump up to 70 - 75 and again the fan speed does not seem to make any real differencing and the cpu block never seems to get warm.
What is going on here?
Idle:
100% load
), a hairdryer will be outputting anything from 300W to 2000W. Also, if the CPU isn't in good contact (which I'm 99% convinced is the case here), there won't be much heat transfer.
