Tuniq Tower query
It comes with its own paste, which I thought was some of the worst stuff I've used! Really difficult to spread. Popped into a well known PC store and bought some Akasa Silver, which worked a treat.
cheers for the help ive got the Arctic Cooling MX-2 Thermal Compound paste that should be ok shouldnt it,and its a case of a thin line across the middle like they show you on the artic silver site,never had to put my own on before always used the pre applied stuff
Pretty sure the single line across the headspreader needs to be applied at a different orientation on a quad than a dual.
http://www.arcticsilver.com/pdf/appinstruct/as5/ins_as5_intel_quad_wcap.pdf
