as above, is it worth changing the fan. as these seem to be pretty good.
is there a similar 120mm x 25mm fan with the same performance but quiter? that is also speed controlable (pwm i think)
or has anyone ever done a push/pull mod to a tuniq tower?
edit. its hard to find the fan specs anywhere, but i found these
RPM: 1000~2000 RPM
Air Flow: 90.65 CFM (Max)
Noise Level: 16~20 +/- 10%dBA
Size: 120 x 120 x 25mm
RPM: 1000~2000 RPM
