Turbo Recommendations/Advice
4 Mar 2008
Wandsworth
Hello all,
Not been long into road cycling, so please bear with any stupid comments! Started back in May on a mates bike, and have now had my own for a couple of months (Ribble Endurance SL Disc). I'm currently doing a fairly intense rowing training programme, which, due to the new lockdown involves a few long bike sessions, and as the days get shorter/colder/wetter, cycling on the road is becoming less appealing.
So looking at potentially getting a turbo to start zwifting etc. (I had looked at rollers as a cheaper alternative, but not sure they would suit long (2/3/4 hour) steady state sessions.
I've been looking around at what's in stock, and it seems some of the Elite units around the £600 mark seem to be about. I'm struggling to find the best out of the Drivo/Direto-X/Suito or other options, so if anyone has any recommendations that would be appreciated?
Also being a complete novice when it comes to any kind of indoor training - do I need to check anything that my bike will fit/the frame won't get damaged etc.?
Cheers!
Hello all,
Cheers!
A good place to start is DCRainmaker - he's just published his 2020/21 trainer guide. Links in there to his reviews of the trainers which very comprehensive and detailed.
https://www.dcrainmaker.com/2020/11/smart-cycle-trainer-recommendations-guide-winter.html/
Cheers for the reply - went with a direto x in the end as Halfords had one in stock!
My bike has a 11-32 cassette on it, but the spare cassette I have lying around that I've put on the turbo is a 11-28, is it normal to need to re index the gears when swapping onto a turbo? Getting an awful lot of noise, and struggling to get smooth shifts on the turbo.
You might need to if the cassettes have different wear.
