Oracle said:Pfft!! Turbos kicking in at 1800rpm for the win!
* if only it wasnt all over by 3800rpm!
lol. yep. i am now converted
Will Gill said:disconnecting the actuator will disable the turbo, probably a complicated way to automate that with some funky stuff, but it would drive like a big lump of poo.
Clarkey said:I wouldn't do that! Disconnecting the actuator will make the turbo boost out of control till it or something else blows up.
eidolon said:Disconnecting it will stop it from boosting. Jamming it open will make it boost of control.
The_Dark_Side said:i drove a caddy a while back and i'm sure when cruising along the engine switches off 3 or 4 of the cylinders.
for the more technically minded (simon, johnnycoupe etc) i have a question.
in cases like this, is it always the same cylinders that are switched off or is the order rotated around all of them?
the reason i ask is, if it's always the same pots that are deactivated then doesn't it put a lot of unbalanced and undue stress on the crank?
Will Gill said:quite bro
its a common mod used when breaking in new engines on scoobs, my mate had a 2.5 and had to do 2k off boost. It nearly killed him but its so good for the engine to be run in like that![]()
Clarkey said:Sorry, i must be losing my mind a little, I thought you meant disconnecting the boost hose from the intake not the actual rod.
LMAO.eidolon said:I've done that on my mates R5 GTT then I took it for a test drive.
I came off a roundabout and floored it, didn't so much accelerate really, just dug a R5 shaped hole in the road![]()
The_Dark_Side said:LMAO.
even now the R5 can be a force to be reckoned with on the road.
pushrods and carb and still it's a little stormer.
Perywinkle said:There are plent of turbo kits around that limit boost to throttle position.
Been looking at some for the R1 engine in my indy that increase boost exponentialy with throttle possition.
eg 25% throttle will give you 10% of maximum achievable pressure, up to a pre desribed max.
Means much more controlable power output on lighter weight cars.
rot boxes to be honest, although i have to agree with you loads of them will have been bent large style.eidolon said:They're deceptively fast little things. I ran 14.5 sec down the strip a few times in mine with mods that cost me about 50p.
I rarely see them these days as I guess most of them have been written off but I've still got a soft spot for them.
when we first locked horns in here it got pretty heated.Will Gill said:I still love r5gtt's, must scan pictures of my past cars, they were all owned way before the days of digital photography
I keep meaning to buy one for £500 and just keep it in the garage and stroke it, I used to just be happy to sit in one and look at the instruments, best instrument panel ever
