You sah, are a star.
Can be done with just iTunes as well.
http://www.fluffypig.com/2008/07/create-free-custom-iphone-ringtones/
If you use a spazzy PC then obviously you need something
like a mac
Kind of an expensive way to make a "free" ringtone though isn't itBest. Answer. Ever.
Bet the OP is a dirty PC owner!![]()
Kind of an expensive way to make a "free" ringtone though isn't it![]()
and a
I might be willing to pay for overpriced tat as regards an iPhone, but a Mac would take the bisuitPut your rolleyes away and join the darkside my friend.
It was all in jest hence both aand a
