turning off a hard drive
30 Nov 2003
i have 2 hard drives in my system. they are not running in raid. i will be periodically backing up documrnents to the spare drive manually.
how do i go about turning off this hard drive between back up times?
my mobo if that is of any relevance is gigabyte 965p-s3
thank you
what OS you are using?
i use Vista and i noticed it automatically turns off the second hard drive after a few minutes of no use and turns it back on again when i start using it.
In the Control Panel, go to Power Options, set the Minimal Power Management scheme and choose a time period there after which your HDDs will, if they're not being used, be turned off.
Katoom said:
Go to the control panel/system/hardware/device manager/ right click on the hdd and disable.
have tried this and disabled the hard drive in device manger, however after checking my noise levels and opening the case confirm it is still spinning!
any advice appreciated on turning off completly i.e. no spinning
also notice my dvd burner is also spinning with no disc in it...never realised they did this.
have tried this and it's still spinning! - am i going to have to open the case and un-plug the molex? :)
come on guys there must be a way of turning off this drive without opening up the case and un-plugging it.
to re-cap the the drive (one of two) is a hitachi deskstar 320gb sata II and is only used to back up once a month.
it's in an htpc so i would like it switched off to keep things quiet and also save energy :)
Will_3rd said:
just unplug the power cable from it in the case, job done
.....sure in a desktop pc no problem , however, it's a bit inconvenient to have to do this as my htpc is in a AV cabinet in my lounge and would have to be pulled out every time. surely there is a better way to do this.
maybe i will have to speak to hitachi ! :)
williamw11 said:
Why not buy a portable HDD caddy and connect it when needed?
seem like the best idea, does everything you want and will only cost you like 20 pound, plus you could store the harddrive off site if your that worried :)
I just disable my hdd from device manager, and it stops it from spinning. But i have trouble enabling it again, I have to restart windows before enabling it or xp hangs while trying to enable it.
actually a sata nas enclosure would be nice :)
i could then put it in the loft (my cable modem and a new router are to be installed in the loft in the next 2 months (cabling is already done underfloor and behind plaster)
the deskstar also runs very cool..only 26 degrees (good for loft temps)
the idea of storing it seperatly would be an added benefit in case the htpc got stolen.
