Turning on issue
13 Feb 2010
Bournemouth
Hi all
A slightly weird issue I believe.
We have a fan plugged into the same extension lead as my partners PC, and occasionally when we turn on the fan, it will also turn on the PC.
Does anyone have any ideas why it does this?
Cheers, Jason
EDIT:
Is your computer in hibernate/sleep?
I would try clearing your CMOS and check your kettle lead is fully in (perhaps swap), and that your case leads are securely fitted to the front panel header (motherboard).
But your extension lead is probably knackered (technical term). Try a different lead or if it's a cheap generic one buy a new, quality, surge protected unit.
Some BIOS option about automatic start after power loss might also help if disabled.
Fan could cause some kind interference for PSU, making BIOS think power loss happened
Cheers for your replies guys.
It's when the computer is shut down, I will have a look at the settings though.
Also it is just a cheap extension lead currently, I have been meaning to get her a proper surge protector one but haven't got round to it yet.
Cheers
