tv card recommend
Permabanned
15 Aug 2006
Gainsborough, Lincs, UK
hi guys, so many to choose from! i see ocuk is stocking compro now over happuciate (cant spell it) wondering if you could recommend me a card.
I want to be able to pause live tv using windows 7 media center, is built in freeview possible?
i dont mind weather it be pci or pcie :)
any help or info shed some light on this subject for me!
Thanks in advance!
HTPC in the build :D
I have had several hauppauge cards over the years , all were great
I tried a compro card once and it was useless
you can buy of other suppliers that stock hauppauge cards .....
which model would you recommend to me buddy?
i wont be using the software included, windows 7 media center... :)
Sorry to nag :)
I've got a BlackGold BGT3510 which I've been very pleased with, and comes with a low profile bracket so can fit into small cases nicely. Works great with Windows Media Centre. Bit pricey though I guess compared with some others.
I *think*, looking at the stats of the Compro T750F, there's only one digital tuner in it (sounds like two but the 2nd one is just analogue). You'd prob be better getting a dual digital tuner card, which I think is what the E900F is, hence the extra cost.
