I have a Cantilever TV wall bracket (weighs around 10kg) that will be extended out from the wall 25 inches in order to hold a 55" TV weighing 23kg. The wall is solid brick with a sheet of 0.8-inch-thick plasterboard on top. Not sure what to use to mount the bracket to the wall, I have heard all of the below are ok. Would greatly appreciate some advice.
1. Ramplug (Large Grey) and galvanized coach screw
2. Ankascrews
3. Expanding/anchor bolts
4. Shield anchor
My main concern is the added weight on the bracket due to it being fully extended outwards.
2. Ankascrews
4. Shield anchor
. I just did not like the idea of using plastic plugs with that amount of weight with it fully extended :/
