What model?All this years OLEDS weight between 17 and 24kg
A cheap way to secure it which puts your mind at ease is to drill the hole, then fill with polyfiller before you put the plug in.
The filler then hardens around the plug and bolt.
How so? I used this method ten years ago and guess what? The bracket is still up on the wall.Sorry but this is really bad advice.
I don’t understand, do you think I’ve installed a wall bracket without the plugs or something?Because polyfiller is not secure like mortar or the brick itself? I have used.poliyfiller to fix problems (massive hole left by tenant, or when drilling hole does not make a good clean hole, hit harder material or steel and goes off to one side) but only for lighter items or curtain or picture frame nor heavy item
As I said it’s been up for 10 years now.Nothing to do with the polyfilla. Its the plug that is securing the bracket. Use a resin system if you want to, not pollyfilla..
