TVersity streaming and sluggish pc
7 Jan 2010
Up NORTH
HI Forum.
Whats making my pc sluggish when streaming to ps3
1156 asus Max formula three
streaming from USB 3.0 external drive
2.80 cpu overclocked to 3.4
4gb ddr 3
Cheers
Not sure what you mean eg watching Benidorm season 3 356mb file
TVersity can convert video files to a another format on the fly, known as transcoding and more commonly used for xbox 360's. If TVersity us set to transcode all, then it will try and convert all the files streamed regardless of it is required or not, this could be the cause of your slow downs
Cheers the options i have is transcode if needed or never or always
im set to only when needed
Try loading the media directly off of the same drive TVersity is installed to.
What does taskmanager show when you're streaming?
From my experience the PS3 isn't very good at streaming wirelessly, the only time I tried it was round a friends to show them PS3MediaServer, it lagged a ridiculous amount and just made the program look terrible :D.
