I'm not sure if that is correct, I was always under the impression that RAID-1 offered slightly better reads than a single disk (as well as offering redundancy).rpstewart said:RAID1 (mirroring) is slightly slower than a single drive
rpstewart said:RAID1 (mirroring) is slightly slower than a single drive. Motherboard based RAID chipsets don't tend to support split reads so there's no improvement in read speed over a single drive and writes take until both drives have finished so can be a touch slower than a single disk.
Also remember that RAID1 only gives you hardware redundancy, it's not a backup. If you mistakenly delete a file it gets deleted from both disks.
No, to do that you'd run them as two separate drives.addylad said:I suppose I could get a tiny raptor to boot from, then put all programs/files on a separate disk?
Would I have to put these in RAID, or just connect them up?
