** TWO NEW PRODUCTS FROM CORSAIR - H105 & OBSIDIAN 250D **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Coming very soon we have these two new products from Corsair.
The H105 promises improvements all round on the current high end cooling solutions from Corsair and the 250D is a brilliant little case with massive potential.
Corsair Obsidian 250D 250D Mini ITX PC case @ £71.99 inc VAT
If you want to build a Mini ITX system without compromising expansion, flexibility, or performance, the Obsidian Series 250D is your answer. Though it's small on the outside, the 250D has room for standard components like a full-size 5.25" optical drive, a full-length GPU, a 240mm radiator, and even a full-size ATX power supply. The sleek, aluminum front fascia provides the striking yet subtle design that Obsidian Series cases are known for, and a top window gives you a close-up view of your high-performance components. The 250D is a great choice if you want full size performance in a small space.
Specifications:-
- Aluminum front fascia and thick steel construction.
- Overall dimensions 290mm (H) x 277mm (W) x 351mm (D)
- Top window for component visibility.
- Thumbscrew backplate removal for PSU and hard drive access.
- Easily removed dust filters on all intakes.
- Simultaneously fit two 3.5"/2.5" drives, two 2.5" drives, one 5.25" drive, a full sized PSU, a 290mm long GPU, and a 240mm radiator.
- Front panel USB 3.0, headphone and mic ports, and power and reset buttons.
- Innovative three panel removal for sides and top panel, with thumbscrews.
- Front fan 200mm, 140mm, or 120mm compatible (AF140L 140mm included)
- Side fans dual 120mm compatible (AF120L 120mm included)
- Rear fans dual 80mm compatible
- Tons of cable routing tie downs for easy cable maintenance.
- Tool free installation of all drives.
Only £71.99 inc VAT.
ORDER NOW
Corsair Hydro Series™ H105 Extreme Performance Liquid CPU Cooler @ £93.95 inc VAT
Installation is easy, with an all-new mounting bracket that provides quick, tool-free assembly. The three included red, grey, and blue accent rings let you match your H105 to your DRAM and motherboard color scheme. And, like all Hydro Series liquid CPU coolers, the H105 is completely self-contained, with no filling or maintenance required.
Extreme CPU cooling performance
The extra-thick 240mm radiator increases surface area significantly for superior heat dissipation.
Take advantage of your case’s 240mm radiator mount
Use your case to its fullest potential with a massive CPU cooler.
Protect your hardware and increase your CPU’s overclocking potential
Keep your CPU frosty at stock speeds or eek out that extra hundred megahertz of clock speed
Dual SP120L fans with PWM control for customized cooling performance
SP120L high performance, high static pressure fans are optimized specifically for radiator usage.
All-new mounting bracket design for easy installation
Thumbscrews and snap-in head mount ring design for quick and easy installation on AMD and Intel processors.
Includes three color accent rings to match your H105 to your motherboard
Default metallic grey, and added red and blue colored rings to match your Corsair Air Series fans or other motherboard, memory, or GPU color themes in your case.
Specifications:-
- Radiator Dimensions:- 270mm x 120mm x 38mm
- Fan Dimensions:- 120mm x 25mm
- Fan Speed:- 800 - 2700 +/- 10% RPM (PWM)
- Air Flow:- 73 CFM
- Static Pressure:- 3.9 mm-H2O
- Noise Level:- 37.7 dB(A)
- Part Number:- CW-9060016-WW
Only £93.95 inc VAT.
ORDER NOW
Wonder how well the H105 compares to the H100i
Very nice design on the 250, you still have room to hide the PSU under the mobo, potential good airflow from a small case.
I wish corsair would do a AIO 360mm radiator as swiftech and coolermaster have done
Please OC get these in stock?
CoolerMaster Glacier 360
The radiator is a bit thicker - 27mm on the h100i, 38mm on the h105.
And different kind of pump, the H100i has the square one with the adjustable LED.
Performance could be significantly better due to the better rad/pump, or worse. Waiting for reviews, I think it's gonna be better :)
Will the fans on the 105 be compatible in a Corsair 750 Obsidian? (not sure how big the grills are on the top of the case).
Also are the fans with the 105 better than the 100s? (not sure if these are the quiet ones?)
rjkoneill, when you get the case in would there be any chance of a side by side pic with a Prodigy? :P
