- 1 Dec 2009
- Staffordshire
i hate buying stuff, something better always comes out a couple months later
I have a request.
Could you add a picture of 250D with right panel off?
And does it allow 180mm long PSUs?
Much appreciated
Specifications
Expansion Room
Two expansion slots and 290mm of internal clearance allow the use of any current stock graphics card.
Supports all modern ATX power supplies, with 200mm of PSU clearance
Two tool-free 3.5”/2.5” combo bays
Two tool-free 2.5” only bays
Full-size 5.25” drive bay
Two front mounted USB 3.0 ports for easy peripheral or external storage device connection.
Cooling Flexibility
Two high-airflow fans are included (1x AF140L and one 1x AF120L) for excellent airflow and low noise levels.
Room for up to 5 fans
Radiator compatibility:Front – 120mm or 140mm
Side - 120mm/240mm
Storage Layout Options
Modular toolless drive caddies can be accessed from the rear of the case.
A pair of 3.5”/2.5” drives and two 2.5” only drives can be simultaneously mounted.
Full-size 5.25” optical drive bay.
Builder Friendly Features
Thumbscrew side panel removal and expansion slots.
Tool-free 3.5”, 2.5”, and 5.25” drive bays.
Easily accessible (and removable) front, side, and PSU dust filters.
Excellent cable routing with multiple tie-down points for improved airflow and cleaner, neater builds.
Two USB 3.0 ports and headphone/mic jacks in the front panel for easy access.
Dimensions and Weight
Height x Width x Depth
11.4 x 10.9 x 13.81 inches
290mm x 277mm x 351.2mm
Weight
4.42 kg
9.7 lbs
Really want the 250D, might be a silly question but does it support Micro ATX? Never understood the mini and micro as in my head micro should be smaller than mini!?
No boards that I know of support AM3+ in mini-itx form, just want to be able to sell my Asus Sabertooth 990FX R2.0 and my Air 540 then buy the 250D and whatever mobo.
Unfortunately not, it only supports mITX. Why not sell your AMD processor and get a i5 Haswell?
Wonder how well the H105 compares to the H100i.
I seriously like both of these products.
