it's a tough call but i would put your problems down to the cpu or the board, something isnt right as you've got a new set of ram, reinstalled and the problem persists granted not as bad as before but to have something similar is very strange, have you looked in your bois at the psu voltage read outs, if one is a bit flaky that may also cause issues, but that wouldn't be related to the ram all the time, have you tested at 2133mhz with the new set and if so how'd that go, if your pc runs smooth as a kitten at 2133mhz i'd say the cpu is the culprit and a replacment should be on your list but only after testing at stock jdec frequencies
(if you test at 2133mhz and everythings fine could be your imc on the cpu is damaged and wont allow higher ram speeds)
