** TWO STUNNERS FROM SAMSUNG!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Two absolutely gorgeous monitors from Samsung and the build quality of these things is unbeliable, the 32" model weighs in at nearly 15kg with stand, these are some heavy solid monitors. Aesthetically these have to be the most stunning monitors we sell. :eek:
Samsung 32D850D 32" Widescreen LED Professional/Gaming Slim Bezel Monitor - Black @ £479.99 inc VAT
Samsungs latest flagship monitor ideal for gamers, professionals and photography experts.
Specification:-
- Screen Size: 32"
- Panel Type: VA
- Backlight: LED
- Brightness: 300cd/m
- Contrast Ratio: 10,000,000:1
- Resolution: 2560x1440
- Pixel Pitch (HxV): 0.27675mmx0.27675mm
- Response Time: 4ms
- Viewing Angles: 178/178
- Colour Support: 1.07b
- Connectivity: Dual Link DVI, DisplayPort, HDMI, USB Hub
- Speakers: No
- Stand Type: Height Adjustable (130mm), Tilt, Swivel & Pivot
- VESA: 100x100
- Set Dimension with Stand (WxHxD): MAX:741.3×630×280, MIN:741.3×500×280mm
- Set Dimension without Stand (WxHxD): 741.3×441×68.5mm
- Warranty: 3yr
Only £479.99 inc VAT.
ORDER NOW
Samsung 27D850D 27" Widescreen LED Professional/Gaming Slim Bezel Monitor - Black @ £419.99 inc VAT
Specification:-
- Screen Size: 27"
- Panel Type: PLS
- Backlight: LED
- Brightness: 350cd/m
- Pixel Pitch (HxV): 0.2331mmx0.2331mm
- Speakers: No
- VESA: 100x100
- Set Dimension with Stand (WxHxD): MAX: 627.4 x 596.3 x 280 / MIN: 627.4x 466.3 x 280mm
- Set Dimension without Stand (WxHxD): 627.4 x 376.4 x 66.1mm
- Warranty: 3yr
Only £419.99 inc VAT.
ORDER NOW
Stock is extremely limited, Samsung predicting they will ship less than 100 units in September and yes they are coming to OcUK. Be quick on these bad boys, SIMPLY WOW!!
Oh god ... just as I'd got down to a choice of 2 you go and show these .... look stunning even from the back!
ETA September on the 32". That's a load more procrastinating time :(
** TWO STUNNERS FROM SAMSUNG!! ** When I read the title I was expecting two female Samsung reps from South Korea, oh well. :(
Nice screens, they look total quality.
If the 32" without the stand weighs less than 10 kilos this will be my next monitor
OC any idea of the weight?
How does VA panel type perform? I've been toying with upgrading from my NEC 24WMGX3 (apparently AMVA type) but it's the best monitor I've ever had so am anxious about inadvertently "downgrading". :confused:
Should have been 4K G-sync with VA panel and I would have swapped my order to one of these without doubt.
Very nice design which Samsung seem to have an affinity for.
Look very nice. Given 3440*1440 doesn't look to be getting practically affordable/justifiable any time soon the 27" looks quite tasty, still hesitant to spend any monitor money on the gaming side with the Oculus stuff all around the corner though.
