Perhaps a slightly odd question that I can't find anything online about - if I connect two Xbox One wireless controller adapters to one PC, would I then be able to sync different Xbox One controllers to each?
I have my PC connected to three different rooms in my house via HDMI and USB extensions through the walls, and my Xbox One wireless adapter can't maintain a signal between the rooms very well. If it's plugged directly into the PC upstairs, it can connect downstairs but isn't reliable and regularly disconnects during gameplay, and vice versa if plugged in downstairs (disconnects upstairs.) If two adapters could be connected, one upstairs and one downstairs, and work independently (I've successfully done this with my old Xbox 360 wireless adapter at the same time as the Xbox One adapter but those are different pieces of hardware) that would solve my problem, but I don't really want to buy another one without some idea if it will work first.
Thanks for any advice!
there is definitely a laziness (convenience) aspect to this whole idea, but I also don't like the thought of constantly unplugging and re-plugging the USB device - probably not the best for durability of the physical connections.
