You don't "need" AHCI.
It will work in IDE mode, maybe not as well, but it'll work.
Strange, I'm sure my 650i Ultra (little brother to 680i) supported AHCI mode. May have been if the board was put in RAID mode.
The toolbox not working is a known issue with AHCI, I have the same.I use vertex2e on a 680i board
Works absolutely fine,only thing that does not seem to work is the ocz toolbox facility which is not really a problem tbh.
But does that mean you run your SSD with AHCI?
@Amraam, maybe you need a BIOS update?
Dutch Guy, I have updated to the latest P33 BIOS as I needed to for it to support the E8400 I just fitted. It's a hardware restriction IIRC.
Is AHCI required for TRIM?
