Tyre fitting prices, what to expect?
18 Oct 2002
Somewhere in the middle.
Ive never bought tires online without fitting, but ive seen some bargain toyo proxes at camskill which would fit my peugeot nicely.
at 28 quid a pop I cant complain, but how much do garages normally charge for fitting. I understand they normally offset this fee with the profit they make selling tires themselves.
Is it likely to cost much for fitting and balancing?
i pay £10 a wheel but others have said they can get it done for as low as £5 each
i certainly wouldnt pay anymore than £10 a wheel.
oops I should spell Tyre right too :D
thanks for replies guys, gives me an idea
i pay £10 a wheel but others have said they can get it done for as low as £7 for a pair
Your up north though!
Usual rate tends to be £12 a corner I find. Did manage to find mobile fitters for £10 each though, score.
I normally try and go to a smaller place which are more likely to take a cash deal. Last time I had 4 tyres fitted for £20.
Edit - That was for the same T1-R's too from camskill. :D
I paid a kwik fit monkey £20 for 4 tyres. It was quiet and his boss was out, so I'm guessing it went into his back pocket
No more than £10 per tyre, EVER. If they try to charge more they are just ripping you off.
I've got my last set done for £5 per as I was having some other work done on car at same place so got a deal
Round my area I was quoted £10 to 20 per wheel for my 255/30/18 rears.
Hi-Q was cheapest (but I know them) Just Tyres were the most expensive.
[TW]Fox;16321007 said:
Should your car not be fitted with 255/35/18's?
mine are meant to be 195/55/15s but the 195/50/15s are considerably cheaper and supposedly handle better due to stiffer sidewalls, although they might look a little bit poo with standard ride height.
too cheap to ignore for me right now though
maybe nick is doing similar
