Hard tyres isn't it? How old are your tyres?
when u turn say left the right tyre will rub against the wheel arches as its spinning and the left slightly slip on the road as it spinning around faster over a shorter distance, whereas the outside tyre will keep its speed as it has a longer route around.
tyre compund does play a role here too
Does your car not have a diff?
Yes compound plays a part, but the main thing that creates squeal is the shape and size of the tread blocks cut iinto the tyre, as they slip slightly against the road surface the tread blocks will vibrate against each other slightly and that causes tyre squeal.
You will not hear tyre squeal on slick racing tyres as they have no tread blocks to vibrate.
aint slicks been banned? unles they have tread?
)If it's caused by the tread blocks though, how do you explain why it happens so much more on certain surfaced though? For example, Pen Rd. McDonalds carpark squeals like hell, and there is one small roundabout which generates massive squeal (begs you to go faster in other words)
They squeal for the same reason you can make your trainers squeal against a hard floor.
It happens most on a smooth shiny road surface. The rubber is skidding across a hard surface and it creates a resonance in the rubber. The same as pulling a bow over a string, only more violent.
Probably won't be much different to the grooved ones they have now tbh. AFAIK just about every other racing series use full slicks, god knows why they were banned in F1 which is supposed to be the pinnacle of motorsport.
