Trying to set up a raid 0 array and failing
Im trying to set up two 160gb, same make hard drives to work in raid 0 on a new install of windows 2000. Im using an asus A8R32-MVP deluxe motherboard
for this. Now first off, whats the difference between the ULI raid facility and the silicon image sata controller?
I tried to set up the raid from the ULI raid configuration which you get to using ctrl-a from start up. Everything seemed to go great but it then reported hard disk size as 320gb and after installing windows the hard drive size was also reported as 320gb. Im guessing this is totally wrong as raid 0 should give me a hard drive size of 160gb. The raid array from the configuration set up did say Raid 0x2 which would be right though.
This is my first attempt at raid and now Im stuck. Can anyone shed any light on what im doing wrong?
