Tz8 not compact enough :(
8 Jun 2006
Hertfordshire
Guys
I have the above and it takes some great pictures but it's not compact enough for my needs I need something I can carry in my pocket and with a case on the tz8 is too big...
Thinking of selling it and getting something smaller but have no idea what?
Any suggestions
Thanks
Mart ;)
Well depends how small you want to go but never had any issue slipping that into a pocket, but looking at the 220 though that looks very compact.
If size really matters (snigger) you're best off getting down to a camera shop or electronics retailer to check them out in the flesh to see which will suit.
Or if you can't find a specific model you like you can at least get an idea of the dimensions you'd be happy with.
May pay a visit to digital depot this week
Thanks
Hmmmmm
I just don't use the TZ enough as I want somethign I can drop in my pocket and forget about...
Going to have a look in the flesh this week
What we talking for the s95? £200 ish?
Not looked at them as yet, are they pocket compact ..
Will take a look
Mart
I picked up the s95 from the rainforest for £230. Very compact with some great features. Well worth checking out as it would appear to fit your requirements as it has a nicer profile and according to the above link the size difference is just over10%. Depends how compact you want to go.
