- 3 Dec 2006
- Oxford
Is there any real reason other than the obvious size difference to get the U3011 over the U2711? I'm currently on a glass Hazro HZ27WD (which is getting returned) and need a replacement monitor. From what I understand, going from the Hazro to the U2711 shouldn't be too much of a change, with the exception of the AG coating instead of the glass - but is the panel used in the U3011 better?
I'm also not totally sure on whether I'd want to go back to 16:10 after using 16:9 for so long - it just seems much easier on the eye now.
Also, are there any other monitors I should be looking at which compete with the two Dell monitors (I'd rather avoid Hazro though). My only real criteria is that if it were a 27" monitor, I'd really have to have it 2560x1440 - I've seen 27" monitors at 1980x... and I doubt I could live with it.
Thanks!
Thanks!
