Ubuntu 6.06 Network problem
7 Nov 2002
Normally in Bed Sleeping
Before I begin I'm a complete Linux Newbie.
OK I've install Ubuntu everything apears to be work fine but i cannot access the internet. If i check the network card I have been asigned an IP and all looks ok, but i cant ping any addresses. Can one of you kind fellas help me out?
No problem here are the details
ifconfig
Code:
eth0      Link encap:Ethernet  HWaddr 00:80:AD:09:E2:57
          inet addr:137.213.35.24  Bcast:137.213.35.255  Mask:255.255.252.0
          inet6 addr: fe80::280:adff:fe09:e257/64 Scope:Link
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:76767 errors:27522 dropped:0 overruns:0 frame:0
          TX packets:6 errors:11 dropped:0 overruns:0 carrier:11
          collisions:0 txqueuelen:1000
          RX bytes:6739618 (6.4 MiB)  TX bytes:480 (480.0 b)
          Interrupt:11 Base address:0xe800
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:891 errors:0 dropped:0 overruns:0 frame:0
          TX packets:891 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:309562 (302.3 KiB)  TX bytes:309562 (302.3 KiB)
resolv.conf
Code:
nameserver 137.213.32.78
nameserver 137.213.32.76
Code:
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
137.213.32.0    0.0.0.0         255.255.252.0   U     0      0        0 eth0
0.0.0.0         137.213.33.150  0.0.0.0         UG    0      0        0 eth0
What equipment are you using? I'm surprised to see eth0 have a public IP address, unless you're using an ethernet modem and no router?
Can you ping the DNS servers and the gateway that you've been given?
I can't ping any addresses. That is an internal address I have been assigned not public
No, that's a public address. Private addresses (see RFC1918) are 192.168.0.0 - 192.168.255.255 (192.168.0.0/16), 172.16.0.0 - 172.31.255.255 (172.16.0.0/12) & 10.0.0.0 - 10.255.255.255 (10.0.0.0/8).
If someone is telling you that is an internal address, then they're either lying or have a shockingly bad idea of how to setup internal IP addressing.
Burbleflop said:
No it doesn't. It say that that IP range belongs to Steria.
Sorry, my mistake - my mind was going off on a tangent, the company I work for deals with Steria and that's why I was thinking work-related thoughts :o
