Ubuntu 6.11 sound problems
23 Oct 2003
I've just installed Ubuntu 6.11 for the first time and I'm trying to set things up and so far things are going ok but I can't get my sound to work I looked in device manager and it lists my soundcard and I've checked alsamixer to see if anything is muted but things seem fine. My Sound card is a Creative Audigy 2 ZS
In a terminal type:
$ sudo lspci
and
$ sudo lsmod| grep snd
And paste that in here.
Ok hope this helps...
$ sudo lspci
00:00.0 Host bridge: Intel Corporation 82865G/PE/P DRAM Controller/Host-Hub Interface (rev 02)
00:01.0 PCI bridge: Intel Corporation 82865G/PE/P PCI to AGP Controller (rev 02)
00:1d.0 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #3 (rev 02)
00:1d.3 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #4 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev c2)
00:1f.0 ISA bridge: Intel Corporation 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge (rev 02)
00:1f.1 IDE interface: Intel Corporation 82801EB/ER (ICH5/ICH5R) IDE Controller (rev 02)
00:1f.2 IDE interface: Intel Corporation 82801EB (ICH5) SATA Controller (rev 02)
00:1f.3 SMBus: Intel Corporation 82801EB/ER (ICH5/ICH5R) SMBus Controller (rev 02)
00:1f.5 Multimedia audio controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) AC'97 Audio Controller (rev 02)
01:00.0 VGA compatible controller: ATI Technologies Inc RV350 AP [Radeon 9600]
01:00.1 Display controller: ATI Technologies Inc RV350 AP [Radeon 9600] (Secondary)
02:02.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
02:07.0 Multimedia audio controller: Creative Labs SB Audigy (rev 04)
02:07.1 Input device controller: Creative Labs SB Audigy MIDI/Game port (rev 04)
02:07.2 FireWire (IEEE 1394): Creative Labs SB Audigy FireWire Port (rev 04)
snd_emu10k1_synth 8960 0
snd_emux_synth 39296 1 snd_emu10k1_synth
snd_seq_virmidi 8576 1 snd_emux_synth
snd_seq_midi_emul 8192 1 snd_emux_synth
snd_seq_dummy 4996 0
snd_seq_oss 36480 0
snd_seq_midi 9984 0
snd_seq_midi_event 8960 3 snd_seq_virmidi,snd_seq_oss,snd_seq_midi
snd_seq 59120 9 snd_emux_synth,snd_seq_virmidi,snd_seq_midi_emul,snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq_midi_event
snd_emu10k1 128288 1 snd_emu10k1_synth
snd_rawmidi 27264 3 snd_seq_virmidi,snd_seq_midi,snd_emu10k1
snd_seq_device 9868 8 snd_emu10k1_synth,snd_emux_synth,snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq,snd_emu10k1,snd_rawmidi
snd_util_mem 6016 2 snd_emux_synth,snd_emu10k1
snd_hwdep 10756 2 snd_emux_synth,snd_emu10k1
snd_intel8x0 34844 1
snd_ac97_codec 97696 2 snd_emu10k1,snd_intel8x0
snd_ac97_bus 3456 1 snd_ac97_codec
snd_pcm_oss 47360 0
snd_mixer_oss 19584 1 snd_pcm_oss
snd_pcm 84612 4 snd_emu10k1,snd_intel8x0,snd_ac97_codec,snd_pcm_oss
snd_timer 25348 3 snd_seq,snd_emu10k1,snd_pcm
snd 58372 16 snd_emux_synth,snd_seq_virmidi,snd_seq_oss,snd_seq,snd_emu10k1,snd_rawmidi,snd_seq_device,snd_hwdep,snd_intel8x0,snd_ac97_codec,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_timer
soundcore 11232 1 snd
snd_page_alloc 11400 3 snd_emu10k1,snd_intel8x0,snd_pcm
Well we know its detecting your sound card.
Code:
By that.
Tried running ALSA config?
$ sudo alsaconf
Make sure you have alsa installed (like all of it, alsa-lib alsa-utils alsa-oss, etc).
BenMorton said:
$ sudo alsaconf <-- will that command install it all?
That will set up alsa...
You need to use apt-get install, or synaptic to get the other stuff.
*note: Personally I dont use Ubuntu, but they are all the same
I tried the command "$ sudo alsaconf" but it said command not known or something. Next I loaded synaptic and installed the other stuff but that didn't appear to do anything and then I install GNOME ALSA Mixer and found when I ran this program it seemed to have detected my motherboard soundcard so I plugged my speakers into motherboard and the sound works but I still would like it to work on my proper soundcard.
alsaconf should be part of the alsa-utils package, so try running it again.
Then run your favourite mixer programme to unmute everything.
$ sudo alsactl store
or add alsa to the bottom of /etc/rc.conf, they will do the same thing.
[EDIT] Apparently the good people at Ubuntu removed alsaconf from alsa-utils starting from Breezy (5.10).... BUT you can download a alsa-utils from here
http://seveas.ubuntulinux.nl/~dennis/alsa-utils_1.0.11-6ubuntu2seveas1_i386.deb
This version has alsaconf in it. Just remember to remove the one you have installed now.
$ sudo debpkg -i http://seveas.ubuntulinux.nl/~dennis/alsa-utils_1.0.11-6ubuntu2seveas1_i386.deb
Or alternatively if you want to do it the more "proper" way:
http://www.alsa-project.org/alsa-do...Blaster+Live+5.1.&chip=emu10k1&module=emu10k1
Do you have any webcams installed? Might sound silly by your Linux distro might think your webcam is a speaker (if it has a built in microphone for example) and be trying to output to that. Double check your ALSA. :)
