I think this is an Ubuntu issue but it could be hardware or a bios setting .
I've got a Zotac Ion mobo that runs Ubuntu . I'm trying to install a graphic card , an ATI Radeon X1300 ( I think ) .
All runs fine on the internal graphic but if I plug in the card I get the Zotac splash screen and can enter bios but as soon as I leave bios the screen goes blank and nothing else seems to happen .
The only setting I can find in the bios that seems relevant ( bear in mind I don't know much ) is in the Southbridge Config .
It's - iGPU and Ext-VGA Selection :
i get two choices the default setting - Disable iGPU if external VGA card exists .
and
Both exisit and iGPU by frame rate buffer .... If I select this one of two things happens .
With no graphic card in place the pc boots into Ubuntu fine on the internal graphic .
Or
With the card installed Ubuntu boots to a black screen with white text that reads as follows:
Ubuntu 10.10 PC2 tty1
Login :
Password :
PC2 is the pc's name in Ubuntu .
if I type my username and password it just comes up with not recognised and asks for login in again .
It's this bit that makes me think it an Ubuntu issue .
Any ideas
and
Or
Login :
Password :
Any ideas
