A whole range of them work nowadays. Just find a few you like and Google whether they work on Linux. Be aware chipsets sometimes change so Google for the exact model.
It's probably a little larger than you want, but last year I bought a "CSL - USB 3.0 SuperSpeed Wireless AC1200 Dual Band network adapter with 2 x 5 dBi detachable antenna " which has a Realtek RTL8812AU chipset. I just installed it again to check whether it works at 5gz. It does. But it wasn't plug and play and I had to install the drivers using these instructions:
I am on Kubuntu 18.04. It's quite a large USB Wifi adapter with two big aerials and a stand. But if you look for something based on that chipset then at least it should work.
