uGuru stopping me?
J86
J86
23 Aug 2005
Ok, so i have an AL8 mobo and i want to overclock my cpu
anyhu, i can get it up to 3.2 ghz from 3.0 standard and anything past 3.2 the monitor just dont turn on and the pc wont boot...(im doin it in bios) i believe its the uGuru crap thats stopping it??? not sure tho
any one have any ideaz? the cpu is cool-as hell and the psu is more than powerful enough
i havent installed the uguru software yet as i reformatted to see if it was that thats stopping it, but uguru is built into the bios too. So the windows software makes no difference
ta
my pc:
ill ive done it put up the clock speed
- Intel Pentium IV 630 'Prescott LGA775' 3.0GHz (800FSB) HyperThreading CPU with 2MB L2 Cache
- Abit AL8 Intel 945P (LGA775) PCI-Express Motherboard
- Corsair 2GB (2x1GB) DDR2 Value PC5300 Dual Channel Kit
- 160GB Western Digital 8mb cache SATA-2 Hard Drive
- XFX GeForce 6800 GT 256MB PCI-Express Graphics card
- Antec SLK3700BQE Case
5bjoshua, could you email regarding the p4.
As for the OP, could you post the settings you have actually changed and the exact ram you have
Edit: Too slow you have already
Make sure the ram is set to 1:1 and is not going higher than the FSB
I have 1GB ram in the moment, 2x512mb as i thought the ram could have been the problem , what would be the setting for this instead please?
Is the P4 Socket 478? Wheres your email?
Also how do i get onto the members market?
EDIT^Found your email...
email is in my trust, i'll answer other questions via email as we are OT already.
OP, should be in the bios somewhere. Set the ram to either 400mhz or 1:1 ratio
if u wonder what i mean by refusing to start..
the monitor does not turn on, and the pc just sits there with power on but making no noise fro mthe processor...
when i turn it off and on again, the settings set them selves back to 3.0ghz
