I've been looking around recently for a player with DolbyVision support without breaking the bank and for that purpose, the Sony UBP-X700 gets mentioned a lot around the £200 mark (but misses HDR10+), along with the Panasonic DP-UB820 around £300 (covers DolbyVision and HDR10+).
Thinking of getting a 4k UHD player to do with a new TV.
Any recommendations of what to buy what to avoid. I'm thinking 150~300 ish.
Go for the Sony…..and you’ll regret it. It’s common knowledge the ub820 is untouchable sub £400.
The Sony models are a real pain. And you have to constantly change DV setting.
No you dont need to change the DV settings at all.
I agree the Panasonic ones have always been the best bar the 3xx and 4xx series ones. There is a about £100 difference between the two (£180 v £299) so just depends
on what you want to spend.
What do you lose by using a ps5?
Literally recieved my first 4k UHD disc today and have been wondering if I should go with a dedicated player or not
As far as I can tell the PS5 is fine, but doesn't support Dolby Vision or HDR10?
Maybe it's HDR10+ that's not supported, if that's different?I would have thought it'd at least support HDR10.
It is different, HDR10+ is more akin to Dolby Vision in that it can use dynamic metadata whereas HDR10 is static metadata.Maybe it's HDR10+ that's not supported, if that's
