ULTIMA HYDROPHOBIA INTEL CORE i7 920 D0 2.66GHZ @ 4.00GHZ DDR3 H2O SYSTEM
11 Dec 2005
Cheshire
"Ultima Hydrophobia" Intel Core i7 920 D0 2.66GHz @ 4.00GHz DDR3 H2O System @ £1,199.99 inc VAT
The "Ultima Hydrophobia" features a Intel i7 920 D0 2.66GHz processor overclocked and guaranteed to a stable 4.00GHz. With a full custom watercooling loop pre-installed the "Ultima Hydrophobia" features silent operation with ultra low temperatures allowing the processer to be overclocked to the highest standard. With a choice of the latest DX11 graphics cards you can select your weapon of choice to destroy the latest games.
Why Should You Buy This System?
- The 4.00GHz overclock ensures lightning fast processing speeds
- Massive 1TB hard drive that delivers rapid load times
- Custom Watercooling for ultimate performance and silence
- Featuring DX11 cinematic graphics
System Specification
- Case: Coolermaster CM 690 Dominator II
- Power Supply: OCZ StealthXStream II 700W
- CPU: Intel Core i7 920 D0 2.66GHz Overclocked to 4.00GHz
- Motherboard: Asus P6T Deluxe OC Palm Edition (Socket 1366) PCI-Express DDR3 Motherboard
- RAM: Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel
- Hard Drive: Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache
- Graphics Card: Choice of the latest DX11 graphics cards
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Watercooling Specification
- Radiator: Black Ice Stealth GT 240mm Radiator
- Pump/Reservoir: XSPC Dual Bay Reservoir/pump (750lph)
- CPU Block: EK Supreme HF Nickel Universal CPU block
- Fittings: x6 Bitspower 1/2" Stubby Barbs Black Sparkle
- Tubing: x2 Masterkleer 7/16" Tubing - 1m (Total 2 metres)
- Fans: x2 Akasa Blue LED 120mm Fan (38.4CFM, 17.5dB)
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
The "Ultima Hydrophobia" provides ultimate performance, cooling and stylish looks in one awesome package. If you like to game with more power, the "Ultima Hydrophobia" is for you.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
The lead time on all pre-built systems is between 24-48 hours.
Only £1,199.99 inc VAT.
ORDER NOW
1200 for a water cooled 920 and a 5750 card? Would have though that there would have been a decent "stock" GPU included for that price. The 920 is a cracking cpu even if the 930 is now out but the 5750 card :/ meh...
There are other options to choose from. For £1200 a fully watercooled system is a rather good deal if I say so myself!
This offer nearly had me believing that I needed a H2O cooled system to run a 920 @ 4Ghz; but there are several bundles around which will run the 920 or equivalent cpu aircooled and come with better GPUs for less money.
Don't get me wrong i am sure this is a great price for prebuilt pc with such quality components - it is just not convincing enough for me when i see the price having changed the GPU to a 5870.
I am still very interested in the Asus P6T Deluxe OC Palm Edition for £119.99 - it may have swayed my decision between AMD and Intel (if only until the wind changes again).
you would be surprised how many people ask for lower power GPUs.
Nath has specced this system with a range of standard choices that cater for most needs.
not everyone uses their computer for games, or has a large res monitor.
a 5750/5770 is more than enough for casual/light gaming.
if you want performance in games then the 5870 and 480 options are there.
this is a good price for a fully watercooled computer.
here are a few examples of OcUK watercooling systems :)
