ULTIMA SR-X DEMOLISHER DUAL SOCKET DREAM MACHINE
11 Dec 2005
Cheshire
Hello you :D
"Ultima SR-X Demolisher" Intel Xeon E5-2650 2.80GHz DDR3 16 Core System @ £6,499.98 inc VAT
Finally we can introduce the most powerful pre-built system ever created, the "Ultima SR-X Demolisher". Truely a monolith of power the "Ultima SR-X Demolisher" features the mighty EVGA SR-X Motherboard. Equipped with two Eight Core Intel Xeon E5-2650 processors the "Ultima SR-X Demolisher" brings a total of 16 cores and 32 threads to the fight, bringing all opposition to their knees. Armed with 32GB of G.Skill RipJawsZ memory you have unlimited amounts of bandwidth availble to you, multitask seamlessly where waiting becomes and thing of the past. The Intel 520 Series SSDs boot Windows and applications up ridiculously fast and delivers earth shattering read and write speeds. With two GTX 690's for graphics the "Ultima SR-X Demolisher" smashes games apart with raw power. If gaming isn't your main objective the "Ultima SR-X Demolisher" will stomp all competition with it's immense folding and crunching power. There is no computing task that this system cannot complete.
Why Should You Buy This System?
- 16 Cores and 32 threads of unparalleled processing performance.
- 32GB of super-fast 2133MHz G.Skill RipJawZ Memory [upgradeable]
- Intel C606 Chipset is the new milestone in computing power
- The NVIDIA GTX 690, the fastest graphics card on the planet.
- 12 Hours of Workstation priority stress testing and quality control.
- Single card SLI performance with the opportunity to upgrade to a dual card configuration.
System Specification
- Case: Lian Li PC-V2120X Aluminium Tower Case
- Power Supply: Corsair Professional AX1200W with Corsair Sleeved Modular Cable Kit
- CPU: x2 Intel Xeon E5-2650 2.80GHz Enterprise Class Processors.
- Motherboard: EVGA Classified SR-X Intel C606 (Socket 2011) DDR3 Dual Socket Motherboard
- RAM: G.Skill RipJawsZ 32GB (8x4GB) DDR3 PC3-17000C9 2133MHz Quad Channel Kit
- Hard Drive: Intel 520 Series 480GB 2.5" SATA 6Gb/s Solid State Hard Drive
- Storage Drive: Hitachi Deskstar 7K4000 4TB SATA 6Gb/s 64MB Cache 7200RPM
- Graphics Card: Nvidia GeForce GTX 690 4096MB PCI-Express Graphics Card (SLI option available)
- Optical: Pioneer BDR-207EBK 12x BluRay RW / 16x DVD±RW 128GB
- Cooling: x2 Phanteks PH-TC14PE CPU Cooler - Red
Service Package
- Full 12 Month Priority collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
This is the ultimate compilation of cutting edge, enthusiast computer hardware. The speed and stability of the SR-X paired with the latest hardware that industry leading manufacturers have to offer will leave other personal computer systems eclipsed.
Concerned about noise? Whilst this system is specified to offer a quiet computing experience, we are able to provide bespoke custom watercooling solutions for this system. Each customer is different and a watercooling solution for your SR-X based system should be as unique as your requirements. We can offer CPU cooling loops as well as multiple component configurations
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow a minimum 72 hours for your system to be built and configured. This may take longer during busier periods or if a custom specification is required.
*Buy any system from Overclockers UK with Windows 7 between now and January 31st 2013 and once launched, you can upgrade to Windows 8 for just £14.99! See full details here:http://www.overclockers.co.uk/LP/windows8_upgrade.php
Only £6,499.98 inc VAT.
ORDER NOW
Only
:p
Seem to get a different price when I click the link though. Also no overclock, madness!
If I was ever to get a pre-built system, this would have to be it. Wow.
I also would love to see some pics of the inside, do we have to wait till someone buys one :O!?
