Ultimate case for air cooling?
15 Jul 2008
I have a MM UFO that I used to use as I was water cooling. After realizing its such a pain to drain the loops for new components I have gone back to air cooling. High end air cooling seems just as good for me. However I have this HUGE MM UFO case that I doubt is best for air cooling. Whats the bast case for air cooling? I will sell my MM UFO and buy whatever case is regarded as the best for air cooling! I want to purchase a Phanteks Ph-TC14PE so that will have to fit in it!
Thanks
Sheldon
Anything massive will be good. Corsair 900d, or the cheaper 800d. I found my Silverstone Raven RV02 a very good smaller air cooling case, as the board is mounted differently, and I personally think it looks the business.
800D, no not air cooling
Doomedspeed The RV series and FT series are very good for air cooling.
800D and 900D are watercooling cases..
I say the 900d will be a great air cooling case as well due to amount of fan mounts.
Having had a HAF-X I can vouch for its air cooling - I ran 2 x 5870's and an i7 950 at 4.0 in it. Was a bit of a dust magnet and the filters could be better on it though. Also as mentioned the styiling is not to everyones taste. Have heard good things about the FT02 as well but was suprised to see the 800D mentioned as this is mainly used as a watercooled case (mine turns up Monday :D )
I've been using an XClio Windtunnel for the last few years. It keeps my overclocked quad core CPU and GTX 680 running fine at a cast temp of 17 degrees with nothing other than its own fans and the CPU sink that OCUK supply with the Krypton bundle. You can't get them any more, unfortunately, but if I had to replace mine it would be with something like the case they made based on the Airbus A380 jet intake.
