Ultimate H100 Cooling Guide
It is indeed a troll vid, but all in good humor, the noise of those 40 fans sounds like a south african football match!!
I'd have thought the lack of frost would have been a give away :p
You beat me too it, just watched it myself. Was amazed at the temps tbh. Would be fun doing something like that though :)
Hello Rufie Fancy seeing you on this board, small world
I wonder how many fans are redundant in that set up . . . 5 Push + 2 Pull per 120mm cooling space ? you'd still get nice low temps :-D
wish adding that many fans to stuff made them below freezing XD
Indeed......more fans dont make the air colder....you couldnt get into the minus figures just by adding loads and loads of fans.
EDIT: just skipped to the end to see it indeed was a troll vid :)
I know it was a troll vid, but "technically" it is possible (but not with this kit). The liquid in the system isn't water so won't freeze at 0 so hypothetically if they could cool the liquid down enough it could go into the minuses and theoretically take the CPU temp there too. And as for getting the liquid down that low, despite popular opinion you can actually cool air below ambient just by using fans as moving air is colder than static air.
Its quite comical how often in the HVAC industry you have to explain to consultants and designers that they have to have A/C because although they can cool the room with just ventilation the velocity required would most likely pin the occupiers to the wall lol.
