Ultra 7 155H, Ultra 9 185H or Ryzen 7 8845HS?
11 Oct 2006
Wiltshire
The new laptop I'm thinking of buying effectively gives me the choice of the above three CPUs with all other components the same (other than chipsets, obviously). Passmark ranks them in ascending order as listed above but I expect there's more to their relative performance than that. As far as I can find out AMD's IGPU is marginally ahead of Intel's, both roughly equivalent to a GTX 1650, which is all I need. So are there any aspects of the Ultras' performance that make them worth the price premium over AMD?
You need to be very careful with your selection as different models of laptop use different power profiles. So for instance ultra 7 might be running a lot lower than the spec suggests.
Noted, thanks. But there's no way of checking this until one has the laptop. I'll probably just stay with AMD to replace my four-year-old R7 4700U.
With those Intel ones you have to be careful what your buying is what's been reviewed especially in regards to the memory speeds. A lot of review samples were sent out with tuned memory running at speeds that are not always available at retail.
If the graphics are important to you I would suggest getting a CPU with the 780m as AMD's software stack is more reliable and consistent (although Intel is a lot better now). On the other hand Intel has hardware accelerated XESS which is better then FRS.
  • Like
Reactions: R3X
So, do you have test results to back that up? And what laptop with a Snapdragon Elite could I get delivered tomorrow?
It was said light heartedly haha
its far too early to tell, but from rumours and some benchmark tests it looks like it could be great
