on the bios i have 'cpu vid tartup value' and it is now set at 1.425 volts. I change it to 1.5 volts to try and get 3ghz out of my processor and when i go back into the bios it hasnet changed.
do i need to change the 'cpu VID control' aswell to make it change? it is prime stable at 2.8ghz but if i move it to 1.5 it will save the bios then just before windows starts it will restart itself. Also i have seen people writing about how they wont go past 1.6volts. my options only go up to 1.55 anyway
also what is the 'cpu vid special control'
thanks
thanks
